Posing in Carrara problem
is in Carrara there is the possibility to mirror a pose similar to studio. I've rigged some characters in Carrara and now I want to mirror the posing of one or the other character. is there an easy way
  • DiomedeDiomede Posts: 15,168
    Hmmm.  It does seem like an obvious sort of thing that should be under the Animation drop-down in the Assemble room, but I find nothing there.
    Or, it is the kind of thing that should be under the Edit drop-down in the Assemble room, but nothing obvious.  I do have an option in this menu called 'Swap' or Control E, but my initial test did not do what I thought it might.  Nor do I remember how Swap got there - whether it came with Carrara or is a plug-in.  If you have a Swap option under Edit, you might experiment with that.
    And speaking of plug-ins, this seems like a task so common and useful that if Carrara did not have the function built in, then DCG or Sparrowhawke or Fenric or Philemo or... would have written one.
    Thanks for asking this question.  I hope there is a positive response.
    I also tried the 'mirror' check box in the motion tab in the properties tray, after selecting a joint.  No luck for me, but perhaps worth exploring.
  • BrianP21361BrianP21361 Posts: 808
    There is a plug-in that does this. It used to be avaialble in the DAZ store, but not anymore. I can't remember the name of it, but I think it was from Fenric.
  • WendyLuvsCatzWendyLuvsCatz Posts: 38,204
    Fenric has made his all stuff available for free but it needs a DAZ/Poser rigged mesh even his BVH exporter does, Carrara rigging is not seen as a figure.
  • RuudLRuudL Posts: 193
    edited April 2023
    @BrianP21361 Perhaps 'Pose Helper' by Fenric ??
    460 x 415 - 74K
    Post edited by RuudL on
    Yes. That's the one I was thinking of.
  • Bunyip02Bunyip02 Posts: 8,602
    edited April 2023
    Did a quick test with one of Stezza's wonderful figures
    Arm and leg raised
    Pose helper sort of/partially worked
    2268 x 1033 - 344K
    2268 x 1040 - 349K
    Post edited by Bunyip02 on
  • KhoeKhoe Posts: 311
    oh jää
    i test it,
    Thanks at all :)
    edited April 2023
    Wendy is right, it needs a DAZ/Poser character.  It works fine with V4
    545 x 772 - 185K
    Wendy is always right. Lol
  • UnifiedBrainUnifiedBrain Posts: 3,588
    +1
    Would be great on a bumper sticker. laugh
    nah, I bury my mistakes well devil
    Perhaps the theme of the next challenge - the Wendy is Always Right bumper sticker.  yes
    Yes it works fine :) Thanks :)
