Help Requests are getting marked solved with no solution again
in The Commons
Once again, some of my help requests have been marked SOLVED and closed for comment. There was no customer service response to the ticket to indicate that anything was fixed. So you might want to check your help requests to see if this happened to you, too.
It may be one of those things where the system just sporadically closed a bunch of tickets on its own like has happened in the past but we will enquire. Can you give us some ticket numbers please?
Here are a couple ticket numbers:
328006
423964
Thanks, sent in the inquiry.
Thank you Frank.
I'm thankful that this system does not (yet ) control the world's nuclear arsenal.
That is reality for every software/hardware business I've ever been employed by. DAZ will be no different. They need to focus on getting the initial release sound.
@frank0314 Did Daz reply with an explanation?
Not yet, sorry.
LMAO thank you for that, needed a laugh.
It happened again.
In this case, the title could also be "How to improve your productivity score without doing any work".
After reading this I checked the one I've had open since June last year. Thankfully it's still open.
It's in the bug tracker as a product fault. So hopefully it will get fixed some day.
This is how it's done now: Kafka runs the support department.
I gave Horse 3 a chance, stupidly believing they'd replace his toupee as they'd hinted before his release, but that didn't happen. And Design Anvil's mane looks like a 50's doo-wop singer's permanent slicked with pomade (albeit with more movement); perhaps the new shaders will remedy this.
