Gen 8.1 Male figure broken after installing Teeth Master Control for Genesis 8 Male
I bought the Teeth Master Control for Genesis 8 Male morph set as I wanted to be able to adjust the teeth on some of my gen 8 and gen 8.1 figures. After buying and installing Teeth Master Control for Genesis 8 Male I was able to make adjustments to the teeth which was cool. After I made adjustments to a character and saved it, I went to customize a new character. I noticed that when I adjusted his mouth via expressions or by manually adjusting the jaw poses that the the top first premolars and most of the teeth on the lower jaw are messed up. I closed the scene and opened up a brand new dev 8.1 character in a brand new scene to see if the issue still persisted, and it did. Attached is a screen shot showing the character with his teeth missing below his gums. This is the base 8.1 male dev figure which I have not applied any customization to. If I open a gen 8 male character, the teeth move properly when you open close the jaw, so the issue seems to be only the 8.1 male figure.
Essentially the steps shortly before the problem occurred was I installed Teeth Master Control for Genesis 8 Male. I used it to make adjustments to one of my highly mixed morph characters. Then when I was happy with the end result and saved my scene, I used shape splitter to merge all of the morphs of my custom character into 1 stand alone morph no longer dependent on the previous morphs. I tested the new character morph out to make sure it worked fine, which it did. Then I loaded a new 8.1 male dev figure to start tweaking which is when I discovered the teeth no longer stuck to the jaw when manipulating it.
Does anyone know how I can fix this? Thanks.
