[Solved] Issues with Mirroring Geometry w/ Mirror Geometry Script by Riversoft
For context, I spent all night trying to figure this out and then with a fresh perspective in the morning realized the issue after some troubleshooting. Hopefully someone will find this in the future and find it helpful.
Whenever I try to use this Script (https://www.daz3d.com/mirror-geometry) to flip a piece of clothing, it comes back with an Error.
I'm trying to flip the cloak from this: https://www.daz3d.com/dark-guard-hd-bundle
But, I've also tried flipping other garments. To test if it was the specific garment. I've followed the direction in the PDF and it produces a file, but it's not mirrored. During the process, it mirror the garment properly, but once it asks me to Update Base Geometry which I select Update Vertex Positions (from current shape). It gives me the following error and put the garment back to it's original position.
Edit: Okay, I actually figured this out. I'm sure it's due to a change in DS, but I had to select (from file) and select the output obj file. Not quite the same as the PDF directions, but it works now.
