Ash Nuin and Arcane Enchantress Horns
Ash Nuin For Genesis 8.1 Female | Daz 3D
Arcane Enchantress Horns for Genesis 8 Female | Daz 3D
What I want to do here is to combine the two. However I've found out they don't play nice with each other. Is there any way to convert one to the other?
Post edited by inspired_art_86a3f09735 on
"Don't play nice" in what way? How are you trying to combine them, and what isn't working?
You can see here that the headpiece covers the forehead, including the eyebrows and covers the top area of the makeup. That's what I mean when I say it isn't playing nice.
I'm trying to add the horns to Ash Nuin, but don't know how to do that successfully.
Because the horns geograft were designed for G8F other than G8.1F, so you have to tweak the surface after loading them to Ash Nuin G8.1F..
1. Select Horns node, go to Surface pane, select 'Face Map' surface;
2. Go to Presets tab, search PBRSkin, dbl-click (Convert iray uber shader to PBRSkin )
3. Select Ash Nuin - 'Face' surface, RMB menu - Copy Selected Surface;
4. Select Horns - 'Face Map' surface again, RMB menu - Paste to Selected Surface.
Done.
