Every Scene loads in completely dark -SOLVED-
LintonLinton Posts: 542
edited May 2023 in Daz Studio Discussion
Hi All,
Not sure what's changed, but now when I load a scene in, the entire scene is completely blacked out. This never used to happen, but now it happens every scene or environment, and I am not changing or doing anything different. It's making posing a figure or placing a prop almost impossible. Adding in a scene or environment light does nothing until i hit render, and when I render it it comes up with all the lighting in tact. While that is okay, when trying to add items into a blackened zone I just cannot do it. Adding a light into the scene doesnt make it brighter either. Any help is appreciated
Two different scenes it happens to are:
https://www.daz3d.com/the-streets-of-japan and https://www.daz3d.com/pose-against-the-wall
Any ideas? Thanks in advance
Linton
Post edited by Linton on
  • LintonLinton Posts: 542
    Attached is an example of pre-render
    1920 x 1957 - 325K
    Try CTRL + L ...
  • Richard HaseltineRichard Haseltine Posts: 101,045
    crosswind said:
    Try CTRL + L ...
    Which will turn off the preview of the lights in the scene, using a pseudo-headlamp instead.
    OMG, such an easy fix, thank you both so much! Crosswind and Richard, thank you!
