D2U Bridge crash
ac_mr_blonde
Hello all,
I just started trying to use D2U bridge and cannot seem to get it to work. It crashes Daz every time right in the middle of the export. This is using the default load of a G8.1 figure with nothing else in the scene, without morphs, just as basic as I can get it (see attached).
It gets through the normal maps, starts something called "convert", and then crashes (see other attached).
Does anyone have any ideas, or has anyone encountered this before? I think I set up everything correctly, but clearly not if I am having this issue with such a simple export.
512 x 668 - 55K
364 x 388 - 22K
1292 x 634 - 204K
Post edited by ac_mr_blonde on
Oh, if it's helpful, in the destination folder there is an .fbx, a .dtu, and a .csv. BUT, the .csv is empty except for a header row, and the .dtu is 0 bytes in size
Try unchecking the Export Material CSV option. There's a crash with that whcih is fixed in newer versions.
That was it, thanks!
