Does "Victoria 4 for Genesis 2 Female" work in Poser?
in New Users
I see that it comes with the DSON Importer for Poser, but the description mentions Autofit, which I thought was a Daz tool. I'm hoping V4 for G2F simply gives me a new figure that I can use directly in Poser, but obviously, I've got a lot to learn about how these things work.
This product provides 3 things:
1) A V4 shape for G2F, which can be dialed on the Parameters pane in Poser.
2) An autofit clone for fitting V4 clothes to G2F -- this only works in DS, although if you use DS also you can autofit, save the result as a G2F outfit and create Poser Companion Files, and then use that in Poser.
3) V4 UV set for G2F, so you can use V4 skins on G2F. There are a couple of utilities for switching UV sets in Poser, as it doesnt give you the option directly.
I think I'm sold. Thank you!
Should anyone else be in a similar situation, this looks like one of the utilities for switching UV sets in Poser: http://www.daz3d.com/forums/discussion/33957/uv-setter-for-genesis-2-revised-and-updated
