create duf files
Hello. I would like to know how I can create my own DUF files.
Specifically I would like to import OBJ models and convert them to DUF.
Greetings
  • rosselianirosseliani Posts: 379
    Whatever you save from the Daz Studio application will be a ".duf" file, whether it's a Pose Preset , a Material Preset, or a full scene.
    Let's say you import a simple cube named "cube.obj", then save it as a Scene Subset named "cube", will create a "cube.duf" file.
    Some exceptions are: ".dsa" files (scripts), ".dsf" files (some data files), and of course rendered images (".jpg", ".png", ".tif", etc.
  • Richard HaseltineRichard Haseltine Posts: 102,890
    If you want to create ana sset, so that the item isn't embedded each time you use it (saves disc space in the long run for items that will be used repeatedly, not really worth it for one-offs) then File>Save As>Support Assets>Figure/Prop Asset - the fields in the option dialogue determine folder names in the data folder, and the drop down at the top lets you specify which content directory to use.
