Distorted V8 figure
I've just uploaded a new V8 figure and she seems to be completely distorted, especially in the region of the hip bones as you can see.
The only shapes that are applied are the Victoria 8 head and body shaping. Reducing them to 0 straightens out the muscles but does nothing to reset the hipbone deformation.
Is this the new normal or is this an error? And if so, does anyone know if there's a workaround or a correction? I'm using Daz 4:21 (64 bit) and W10 version 21H2
Thanks in advance
"Currently Used" does not show dials that have non-zero default value, ie. you probably have one that is applied by default.
Zero the Figure, enable showing hidden properties and have a new look at "Currently Used", any dials that are not at their default value, should show up with the zero value in white letters.
Thank you. That seems to work.
