Morphs example Hob Goblin HD
Hi guys,
i really like the genesis 2 figures but i have a little problem with morphs. For exampel the Hob Gobling i used all morphs in the pack but it change only a bit but not how really have to look.
I hope anyone have an idea how i can fix the problem. With g2f have i the same problems and sometimes i dont get the morph dials and i dont know why.
Post edited by kayto93_073094d40c on
There are 'Presets' for this item as well
If you installed with DIM, go to the Installed tab, right click, and select 'Show Installed Files'. That will show what has been installed and where.
i have this fils and i know where they are. And its in the content db maintenance too when i re import the metadatas but its not working. I installed it new again but the same problem.
And this problem is with the most of my morphs for g2f g2m i think sometimes with g3f too
What isn't working exactly? If you can post a screenshot of the content you are trying to use, it would be most helpful/. In some cases, Presets are just for changing the Material on a figure that you have already loaded, and you must have the Character selected in the Scene pane first.
first pic the charakterfils
second pic loading the charakter
third pic slide bar on 100%
second file sry and its already a charakter file but i tryed it with m6 too how you said but the same
Can you go to Edit > Preferences > Content Library > Content Directory Manager, expand the "DAZ Studio Formats" section, and post a screenshot?
with v4 i had that problem too but there i knowed that i need other stuuf how creatore creator stephanie etc but here i dont know what i need and the head sliders is perfect but the body slider dont work and the charakter morph in the library dont work too
u mean this?
You've got a few problems with your directory listings:
the second and third entries are wrong, the path shopuld end at the folder CONTAINING the Data or Runtime folder
I cant read the full path on the 5th entry -- does it end at "Victoria 7 Pro Bundle" or does it go one folder further to "Content"?
yes its victoria 7 pro bundle and in it is content data and templates and in the content folder are all the stuff. There are data too in it the morphs. i saw yesterday all my dsf morphs dosnt work. But i dont get the error screen its just not loading. in other forum they say its a bug with genesis and something with new genesis, undo and than there are the morphs but not true. The morphs for clothes dosnt work too.
The folder naed "Content" underneath the Pro Bundle folder shouldn't be there, that's why the morph data isn't being found. Move everything inside that folder named "Content" up one level so the Data folder merges with the one that's directly under Pro Bundle.
ahhhhh nice now it work. Thank you for your great help :)
