Loading morphs from DeviantArt
in New Users
Hello, so I have successfully loaded some downloaded characters into my library, but I would like to try adding some head morphs from Magnus1781 on DeviantArt to make some movie characters look more accurate. I downloaded one, but I have no idea how to use it. I don't quite understand everything in DS yet (been using it less than a week). Any help would be greatly appreciated.
828 x 1792 - 1M
The files should be in .dsf format, in which case they would go in /data/daz 3d/genesis 8/male/morphs/somefolder (assuming that is Genesis 8 Male) in one of your content directories (e.g. /Documents/daz 3d/studio/my Library/)
Normally there's only one 'data' folder in the downloaded file of such 'morph only characters'. You dump this 'data' folder to the root path of your Daz Library, then reload a G8M or a G8F base figure to the scene, go to Parameters pane, type the character's name or a keyword in the filter field, you may locate the corresponding morph dial(s). If there's a Readme.txt or documentation folder or sth. like that in the downloaded file, also check them in which the author might give some guideline of How-to-use as well。。。
