one-liner script to send the selected object's origin to 0,0,0
mCasualmCasual Posts: 4,607
edited May 2023 in Freebies
say you create a 1000 meters diameter Primitive-Sphere
and you specify that the origin of the sphere should be at the center of the sphere
the bottom of your giant sphere will be created sitting on 0,0,0
but you want to use this sphere as an environment sphere for openGL or 3Delight
in the parameters tab, you see that the Y-Translate sliders is at 0
so , you now have to figure uhhh what's half of 1000 meters in centimeters, is it 5000 500000 or 5000000
so instead of straining your brain beyond repair on such a higher mathematics problem,
you select the sphere and run this script:
Scene.getPrimarySelection().setWSPos(DzVec3(0,0,0))
dsa
dsa
mcjSendSelectedNodeTo000.dsa
53B
Post edited by mCasual on
  • mCasualmCasual Posts: 4,607
    edited May 2023
    though in my case it's a tiny sphere i wanted at 0,0,0
    1466 x 849 - 583K
  • Catherine3678abCatherine3678ab Posts: 8,384
    Thank you :-)
