Clipping - Clothes creation - Adjusting tight shapes
Hello,
That's a dumb question (I'm least I'm aware :-p) but what is the best way to adjust tight shapes for custom clothes? Do I have to fix it in Blender and import again each time? It seems to ignore morph deltas and updating geometry make things worse. Any advice?
  • GordigGordig Posts: 10,175
    The easiest solution is to add a smooting modifier (Edit -> Figure -> Geometry -> Add Smoothing Modifier).
  • arthenicsarthenics Posts: 143
    Thanks. It works pretty well for tights but... for shoes, it's not the case. Any alternative?
  • felisfelis Posts: 4,649
    A push modifier?
    It works. Thanks.
    The question is related, then I'm not sure if I have to create another topic, I wil ask here first :
    For a product : should I save with the smooth and push modifier or it is better for users if it's not added (depending of what they are doing if there is already a modifier it could create conflicts?)?
    It is quite common saving with a smooth modifier.
    For push modifers, I see them more as a fix for certain situations, so in the default pose/shape it shouldn't be needed.
    I can't see how it could create conflicts, as the settings are per object.
