Any way that "DzColorWgt" initially displays a given color and not only white? [Solved]
![V3Digitimes](https://delorean.daz3d.com/forums/uploads/userpics/651/nMZZ4LL08HIDE.png)
Good morning,
I try to set a given initial color to DzColorWgt, but it seems that I only can start from white (255 255 255).
Does any one know if there is a way to start from another color?
Thanks!
Post edited by V3Digitimes on
Does setting DzColorWgt.value = colour not work? I just tested (and forgot to copy the code before closing DS) and
gave the expected result.
Thank you Richard !!! It works.
I did not think I could write ".value" with a widget too... Ok, next time I have a doubt I will try a ".value", since this is not the first time the answer is as simple as a ".value". I set the subject status as "solved" ;)
Not all widgets provide the same APIs, so it is not safe to assume that the
value
property will exist on just any widget. Thevalue
property is provided specifically by the DzColorWgt object.-Rob
Thanks Rob. I went to this page several times today, but I understood it wrong. The page is fine no worry. But with my own english language and scripting language limitations, instead of using DzColorWgt.value I was trying to use DzColorWgt.Color. I did it the wrong way. And of course it did not work.
Now it is solved, and it works great! I'm so happy to see everything possible with scripting.
