Genesis 9 Tongue 100% on loading and posing?
Does anyone else have this problem. Genesis 9 has the toungue out 100% when loading or posing! Is this a general bug or?
  • crosswindcrosswind Posts: 7,880
    edited June 2023
    I found no Tongue related morph dialed on loading..  What is the morph dial exactly?
    Default is as attached...
    508 x 1302 - 62K
    Post edited by crosswind on
  • Richard HaseltineRichard Haseltine Posts: 102,310
    That sounds as if an add-on is loading with a non-zero value - when you load the figure all cotnrols are loaded, so that the Parameters pane can be populated, and if they are saved with a non-zero value they will be applied. If you have a control showing at 100% is it from an add-on? If so that is likely the culprit, and you should contact support (the artist for items not from Daz). If not, try clicking the gear icon on the slider and then select Parameter Settings - there should be a tab labelled Controllers, one of the items there will most likely be the problem so make note of them and try each in turn until you find the one that is loading at a non-zero value.
