Issues with Rendering
Hello,
I am trying to render this image, but I noticed that it's very dark, hazy, and grainy. Also it's got a bluish hue. Any suggestions or tips that I can do to improve this? See the image below it's a preview, but it shows about the same on the render. Additional information, I am using a 4060TI graphics card. Thank you!
  • FirstBastionFirstBastion Posts: 7,851
    edited June 2023
    We can't see any image,  but generally if an image is dark and grainy  it is due to the default HDRI not shining on the scene,  because something in the scene is blocking the light from reaching the subject. Is it interior?  Is it a set you bought at this store?  Tell us which one and we might be able to help.
    Post edited by FirstBastion on
  • j3studiosgamesj3studiosgames Posts: 5
    edited June 2023
    No this is suppose to be outside.I can't seem to upload images or pictures on here, DAZ3D team needs to fix that on their end.
    To Answer your other other question, yes this is a set I bought: https://www.daz3d.com/1stb-long-stretch-of-forested-road-add-on and I also bought this with it because its only an add on to this: https://www.daz3d.com/1stb-long-stretch-of-deserted-road
    Post edited by j3studiosgames on
  • Okay, so I managed to post a picture, please see the attached document. Also see the message above for the set that I bought.
    961 x 661 - 357K
  • Richard HaseltineRichard Haseltine Posts: 102,885
    Are you using the Iray or 3Delight files?
    For the engine, I am using NVDIA: IRAY (MDL)
  • crosswindcrosswind Posts: 8,122
    They're just FirstBastion's products cheeky ... the color looks a bit weird... You added an HDRI to the scene?
    Yes, but have you loaded the 3Delight or the Iray version of the scene?
    577 x 106 - 12K
    564 x 105 - 15K
  • prixatprixat Posts: 1,590
    edited June 2023
    It might be the age of the set and that Iray has changed quite a lot since then. The materials may need a tiny bit of tweaking.
    Just tried the base set and it seems to be very sensitive to different HDRI files. Have you tried other HDRI files?
    Post edited by prixat on
    Hmm... if OP loaded the Road with 3Delight Preset, he would have no way to preview or render that 'blueish pic' with Engine - NVDIA: IRAY (MDL)....
