Section 18 and Feisty Feather Bun Hair crashing Studio.
jd641jd641 Posts: 459
edited June 2023 in The Commons
This combo keep crashing crashes for me. If anyone has both Stone Mason's Section 18 and Chevybabe's Feisty Feather Bun Hair, could you please load up the SM set then the hair and see if it crashes your iray render?
With nothing but the set and the hair my render/studio crashes 100% of the time. Checking the log file I see this at the end:
2023-06-24 15:26:09.291 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(369): Iray [ERROR] - IRAY:RENDER ::   1.5   IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 3060): Kernel [21] (RoundedCorners    ) failed after 0.227s
2023-06-24 15:26:09.291 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(369): Iray [ERROR] - IRAY:RENDER ::   1.5   IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 3060): an illegal memory access was encountered (while launching CUDA renderer in <internal>:951)
2023-06-24 15:26:09.291 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(369): Iray [ERROR] - IRAY:RENDER ::   1.5   IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 3060): Failed to launch renderer
2023-06-24 15:26:09.292 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(369): Iray [ERROR] - IRAY:RENDER ::   1.17  IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 3060): Device failed while rendering
2023-06-24 15:26:09.292 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(369): Iray [WARNING] - IRAY:RENDER ::   1.17  IRAY   rend warn : CUDA device 0 (NVIDIA GeForce RTX 3060) is no longer available for rendering.
2023-06-24 15:26:09.292 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(369): Iray [WARNING] - IRAY:RENDER ::   1.17  IRAY   rend warn : All available GPUs failed.
2023-06-24 15:26:09.292 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(369): Iray [WARNING] - IRAY:RENDER ::   1.17  IRAY   rend warn : No devices activated. Enabling CPU fallback.
2023-06-24 15:26:09.293 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(369): Iray [ERROR] - IRAY:RENDER ::   1.17  IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 3060): an illegal memory access was encountered (while initializing memory buffer)
2023-06-24 15:26:09.293 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(369): Iray [ERROR] - IRAY:RENDER ::   1.17  IRAY   rend error: All workers failed: aborting render
2023-06-24 15:26:09.293 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(369): Iray [ERROR] - IRAY:RENDER ::   1.17  IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 3060): [Guidance sync] Failed slave device (remaining 0, done 0).
2023-06-24 15:26:09.293 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(369): Iray [ERROR] - IRAY:RENDER ::   1.17  IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 3060): an illegal memory access was encountered (while de-allocating memory)
2023-06-24 15:26:09.294 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(369): Iray [ERROR] - IRAY:RENDER ::   1.17  IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 3060): an illegal memory access was encountered (while de-allocating memory)
2023-06-24 15:26:09.294 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(369): Iray [ERROR] - IRAY:RENDER ::   1.0   IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 3060): an illegal memory access was encountered (while de-allocating memory)
2023-06-24 15:26:09.295 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(369): Iray [ERROR] - IRAY:RENDER ::   1.0   IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 3060): an illegal memory access was encountered (while de-allocating memory)
The error report lists this error:
DAZStudio.exe caused ACCESS_VIOLATION in module "C:\Program Files\DAZ 3D\DAZStudio4\libs\iray\libiray.dll" at 0033:000000009A2FF6C4, mi_plugin_factory()+1859556 byte(s)
Post edited by jd641 on
  • thd777thd777 Posts: 943
    edited June 2023
    Hello!
    I gave it a shot. If I just load the set and the hair, I also get a crash and DS closes. Once I switch  "Render Line Tesselation Sides" from the default 0 to 1, it works fine. Puzzelingly, the set and the hair by themselves render without issue with line tesselation at 0, just when you have both in the scene there must be some funny intweraction...
    Ciao
    TD
    900 x 630 - 897K
    Post edited by thd777 on
  • chevybabe25chevybabe25 Posts: 1,269
    Several people are looking into this now. Seems like a really odd bug.
  • memcneil70memcneil70 Posts: 4,224
    You might want to post this in the Commercial thread where Chevybabe25 can see it. Or see if others are seeing the same issue.
  • jd641jd641 Posts: 459
    lol yeah it's really odd. But this is typically my luck, the one combination of things that I really wanted to work... doesn't. hahahha
    If this can't be fixed because it's an iray issue I'm gonna be super bummed that I'm going to have to switch to another hair cause Feisty Bun is awesome.
    edited June 2023
    See my post above as a work around, you can chnage the "Render Line Tesselation Sides" setting from 0 to 1. Then you can render the hair in the environment. At least that works for me.
    TD
  • AllenArtAllenArt Posts: 7,169
    Oddly, happens to me too. LOL
    Strange ;)
    TD
    It renders but it also makes the hair a strangely shiney light color, and the hair strands start to look not quite right close up, but yeah at least it renders doing this. Hopefully there's an easy solution to this issue and it's not something too complicated. crying
  • TotteTotte Posts: 14,028
    edited June 2023
    If you select all Material zones in Section 18 and turn off Round Corners Across  Materials and Set Round Corner Roundness to 0.0, DS stops crashing.
    The first log message is "GeForce RTX 3060): Kernel [21] (RoundedCorners    ) failed after 0.227s"
    So I hunted there first.
    Screenshot coming then the forum hamsters decides its OK to upload files again.....
    Edit: Finally could upload the screenshot:
    286 x 87 - 11K
    Post edited by Totte on
    That works, thank you.
    I guess it's some type of conflict between the rounded corners in the scene and the rounded corners used by the hair. I wonder if that means two products using rounded corners will make it crash due to some iray bug/limit. I know that Chevy is aware of the issue but I haven't seen an update on what the cause actually is. So far it's the only situation where I've had the issue, but it's just so strange... lol surprise
