Help Smoothing Out Intergenerational Hair
When using Genesis 1 and 3 hair on my Genesis 2 figures, I notice a few jagged edges and strands to varying offenses on some hair models, and "enable smoothing" is not always available. Are there any tips on smoothing out the hair?
  • LeanaLeana Posts: 11,728
    When using hair made for older figures, I usually don't autofit them as rigging resulting from automatic conversion is often not ideal, especially for long hair.
    Instead, I load the hair without fitting it, then manually position it using translation / rotation / scaling / adjustment morphs, and then parent it to the figure's head.
    It's easier to do the basic positioning in default pose, so if my figure was already posed I first use "memorize figure pose", then zero the pose, position the hair, and restore figure pose after hair has been parented.
  • Bat22Bat22 Posts: 45
    Thank you for the response. It takes a bit of time and experimentation, and it may never seem quite right to me, but you're right that the result is superior to the auto-conversion.
