Rina Wedge High Heel Shoes
bombenleger58bombenleger58 Posts: 108
edited July 2023 in The Commons
I can't change the Materials by [Rina Wedge High Heel Shoes] the Props!
Fehler:
2023-07-14 21:05:54.565 [INFO] :: Begin asset load (merge): /People/Genesis 9/Clothing/Footwear/PrefoX/Rina Wedge High Heels/Materials/RWH 15 Beige.duf
2023-07-14 21:05:54.578 [INFO] :: Determining missing assets...
2023-07-14 21:05:54.615 [WARNING] :: Invalid hierarchy for selected node(s) and "preset_hierarchical_material" type; no root(s) found.
2023-07-14 21:05:54.615 [INFO] :: Error loading asset: D:/Contents I/Genesis 9/People/Genesis 9/Clothing/Footwear/PrefoX/Rina Wedge High Heels/Materials/RWH 15 Beige.duf
2023-07-14 21:05:54.615 [INFO] :: Operation failed
Have anyone the same Problem?
  • felisfelis Posts: 4,561
    That means that you have selected the wrong object for applying the material.
    Try to select the character and apply it again.
  • Richard HaseltineRichard Haseltine Posts: 101,876
    If you have fitted or parented the shoes to another figure either parentthem to genesis 9 or load a second version of the shoes, fitted and parented to Genesis 9, apply the materials, then save out regular materials preset.
  • PrefoXPrefoX Posts: 246
    you guys missunderstood bombenleger I guess.
    He is totaly right. I saved all materials hierarchical so they don't work with the prop shoe, I didn't think about it and the DAZ tester neither. so the only options are, no hierarchical materials or an extra folder for the prop materials.
    you can load the normal shoe, apply the material you want and copy it over to the prop
