Post apocolyptic terrains
rampart_1576840087rampart_1576840087 Posts: 504
edited October 2015 in Carrara Discussion
I need to build several complex terrains with post-apocolyptic buildings, etc.
These scenes will finish out much larger than a 30x30 scene.
Is there a tutor for doing this with Carrara terrains?
Below is a backgrounds content package with the kind of 3d scenes I visualize will work.
The problem is backgrounds are not sufficient.  I need to produce scenes for walkthrough, drive thru, flyover.
I believe I can do the scenes for the 30x30 well enough with what I have.  I have a pretty good supply of rubble, destroyed stuff,etc.
My concern is the scenes where vehicles, helicopters are driving and flying into, around and through destroyed infrastructures.
I realize there are stronemason and several other packages, which are good.
Producing  video takes alot of content at 30 frames per second. The cost for purchasing enough pre-made related scenes is just NOT in an Indie budget.
It may be that someone has produced what I need, which I've not found.
I shoudl at least ask, if there are terrains with post-apocolyptic buildings, rubble and other junk?
I have found some content packs with abandoned buildings, vines gorwing up and other rubble (not what I need).
I need damaged partically destroyed, buildings and infrastructure  which communicate chaotic destruction.
The reason I mention terrains is because I need reasonably larger covered areas, especially for fly-overs, and fly-ins.
I just now thought... what I am talking about is partially, choatically destroyed cityscapes
http://www.turbosquid.com/3d-models/ruined-destroyed-city-3d-model/522867
The turbosquid is a gooe example, but no way affordable for indie video
http://www.daz3d.com/ron-s-apocalypse
Post edited by rampart_1576840087 on
