Vinme Morphs for Genesis 9 Duplicate Formula
![MelonArts3D](https://delorean.daz3d.com/forums/uploads/userpics/656/nM8K08M2KZ51G.jpg)
Hello,
so I'm getting the duplicate formula error every time I load up a G9 figure..
2023-07-21 17:01:23.749 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(7158): Duplicate formula found linking yOrigin & 06 Vinme Abdomen Length in F:/Libraries/My DAZ 3D Library/data/Daz 3D/Genesis 9/Base/Morphs/TMDesign/Vinme Morphs/Vinme Abdomen Length.dsf.
2023-07-21 17:01:23.750 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(7159): owner: Genesis9
2023-07-21 17:01:23.750 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(7160): output: hip:/data/Daz%203D/Genesis%209/Base/Genesis9.dsf#hip?center_point/y
2023-07-21 17:01:23.750 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(7161): input: Genesis9:/data/Daz%203D/Genesis%209/Base/Morphs/TMDesign/Vinme%20Morphs/Vinme%20Abdomen%20Length.dsf#Abdomen%20Length?value
2023-07-21 17:01:23.765 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(7158): Duplicate formula found linking zOrigin & 06 Vinme Abdomen Length in F:/Libraries/My DAZ 3D Library/data/Daz 3D/Genesis 9/Base/Morphs/TMDesign/Vinme Morphs/Vinme Abdomen Length.dsf.
2023-07-21 17:01:23.765 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(7159): owner: Genesis9
2023-07-21 17:01:23.765 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(7160): output: hip:/data/Daz%203D/Genesis%209/Base/Genesis9.dsf#hip?center_point/z
2023-07-21 17:01:23.765 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(7161): input: Genesis9:/data/Daz%203D/Genesis%209/Base/Morphs/TMDesign/Vinme%20Morphs/Vinme%20Abdomen%20Length.dsf#Abdomen%20Length?value
2023-07-21 17:01:23.779 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(7158): Duplicate formula found linking yEnd & 06 Vinme Abdomen Length in F:/Libraries/My DAZ 3D Library/data/Daz 3D/Genesis 9/Base/Morphs/TMDesign/Vinme Morphs/Vinme Abdomen Length.dsf.
2023-07-21 17:01:23.779 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(7159): owner: Genesis9
2023-07-21 17:01:23.779 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(7160): output: hip:/data/Daz%203D/Genesis%209/Base/Genesis9.dsf#hip?end_point/y
2023-07-21 17:01:23.779 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(7161): input: Genesis9:/data/Daz%203D/Genesis%209/Base/Morphs/TMDesign/Vinme%20Morphs/Vinme%20Abdomen%20Length.dsf#Abdomen%20Length?value
And it keeps going, like for ages there is only this in the log..
Can someone tell me what the problem is? Did I f**k up my library or is this a known issue?
Thank you.
Yes, both the Vinme and Shape Shift products for Genesis 9 use the same names for at least one property, causing the issue. There is a fix, editing files, pending an official fix for one or both products. https://www.daz3d.com/forums/discussion/comment/8207516/#Comment_8207516
