Change Directory Path From One Drive or Reinstall DAZ Studio
![IceScribe](https://delorean.daz3d.com/forums/uploads/userpics/367/n1LM2NORVK4NZ.jpg)
The Content Manager directory shows my installed DAZ Studio as "C:/Users/name/One Drive/Daz 3D/Studio/My Library" (can't upload pic)
I want to edit that path that to "C:/Users/name/Daze 3D/Studio/My Library" removing One Drive.
Can I do that and retain the associated folders in Studio? ie installed products?
Or Reinstall?
You need to change the the path in Preferences > Content > Content Directory Manager in order to tell DS where your content is installed.
And then you must tell DIM the new path (in advanced settings), so it know where to install. But you will also need to update all the manifest files with the new path, else DIM won't know what is installed (assuming you are moving the existing files) (it uses the manifest files for that). The manifest files are simple text files that can be edited with a text editor, but as there is many manifest files (one per product) you want to use something that can batch edit all the files, e.g. Notepad++.
First, let's stop OneDrive.
