Install Manager fails
New to Daz and excited I finally have a computer capable of running it. I downloaded the install manager. Open it up, logged in, and it fails to install anything. I can't do anything at all. Each flashes and then goes red with "retry" which does nothing. I'm so disappointed.
  • frank0314frank0314 Posts: 14,274
    Can you show a screen shot of it please
  • Richard HaseltineRichard Haseltine Posts: 102,464
    Try clicking the account name at top-right of Install Manager, then relogin - sometimes that helps when it gets stuck.
  • SofaCitizenSofaCitizen Posts: 1,955
    edited July 2023
    Check the log or helper log (cog icon menu) just after one of these items failed.  If you see the following lines, then it is/was a known issue:
    [WARNING] :: SSL Error: 11 - The issuer certificate of a locally looked up certificate could not be found
    [WARNING] :: Network Error: 0 - : SSL handshake failed
    Not sure if the latest DIM update fixed this or not.
    Post edited by SofaCitizen on
  • FluxFlux Posts: 17
    edited September 2023
    [WARNING] :: SSL Error: 11 - The issuer certificate of a locally looked up certificate could not be found[WARNING] :: Network Error: 0 - : SSL handshake failed
    The issue SofaCitizen mentioned is still present in the latest DIM: 1.4.1.62_Win64.
    [WARNING] :: SSL Error: Unable To Get Local Issuer Certificate - The issuer certificate of a locally looked up certificate could not be found : Certificate is valid[WARNING] :: Network Error: 0 -  : SSL handshake failed
    I'm having the same problem and can not install any product.
    After clicking the download button it just changes into a red retry button.
    It is a really frustrating issue.
    Post edited by Flux on
  • crosswindcrosswind Posts: 7,958
    Have you tried the way in this thread to fix it ? - https://www.daz3d.com/forums/discussion/comment/8126081/#Comment_8126081
    Their log says:
    "Error connecting to CMS - Cannot be started by client."
    I can connect to CMS and my error message is different, although it might just be the same issue.
    "[INFO] :: Starting CMS..."
    "[INFO] :: Connected to CMS: PostgreSQL 9.3.4, compiled by Visual C++ build 1600, 64-bit"
    I did not try to install DazCentral, as in the post. DIM was working without DazCentral just fine before I upgraded my motherboard and installed DIM on the new PC.
    What I did try is in the following post: https://www.daz3d.com/forums/discussion/comment/7918666/#Comment_7918666
    I installed DAZStudio and PostgreSQLCMS from offline DIM, then going online, but it did not solve my issue.
    They submitted a ticket to support about it in december 2022. That is 9 month ago and they still couldn't fix it. Wow!
  • Those INFO lines are not errors - that is just a log what what is happening.
    Did you try downloading the cert file from godaddy as in the link posted above?
    I didn't say those are errors, in fact I quoted them to show that my error messages are not the same as in the linked post.
    DIM can connect to CMS for me, yet it doesn't download my products.
    I downloaded the gdig2.crt file, but it is a security certificate from an unknown publisher. I did not use it.
    466 x 344 - 16K
