Head darker then the body - Skin textures don't match
Hi, I have the issue where skin textures of the head don't match with the body. Head is always darker then the body. I tried to delete translucency maps, lower them down, but it's still there. The textures are alright, parameters too (checked for a whole hour). Any ideas on how to resolve this issue?
  • FenixPhoenixFenixPhoenix Posts: 3,114
    Select another texture (the body/torso) in the surface tab (windows > tabs> surfaces) and with shift select the head. Then go through the settings to see where you see a ? sign. That will tell which setting might be off. If the problem isn't in the maps, you should be able to match the settings so that all values are the same. That could be one way to solve it.
  • Richard HaseltineRichard Haseltine Posts: 102,480
    If that doesn't find the issue it may well be the gamma setting for one of the maps, unfortunately there isn't a built in tool to multi-view those (I don't know if the vlaue is accessible to scripting) so you will have to select teh Image Editor (not Layered Image Editor) command from the image menu on each mapped property.
