How do I just copy keyframes from one character to another?
So, I have keymate open, and Ideally it would be absolutely just as simple as, select the source figure, select intended keyframes, copy, select destination figure, paste, done.
Nothing more nothing less.
But whether I try to do that in Keymate or Timeline, no dice.
In the simplest terms possible, how can I just move all the keyframes in a figure to another figure?
  • Catherine3678abCatherine3678ab Posts: 8,386
    I don't know, I'm not too advanced with animations however, what I would try would be to save out an animation pose of the 1st figure, [make sure that the required frames are selected for the pose save], then apply that pose to the 2nd figure.
  • togstogs Posts: 11
    This is an old post, but hopefully it will help someone else...
    Select the figure you want to copy from.
    In the main menu, choose Edit > Copy Figure
    Select the figure you want to copy to.
    In the main menu, choose Edit > Paste Figure Pose.
    It copies all keyframes, as far as I can tell.
  • pamacachpamacach Posts: 4
     Confirm, that´s works, thanks.
