changing face features
wiibbwiibb Posts: 0
edited August 2012 in New Users
I am having a lot of trouble changing the features on V4 face
how would I go about chaining the simile or even an angry face stuff like that?
Post edited by wiibb on
    Can you let us know which program you are using. Poser ? Daz Studio ? or another one.
    and which version of the program.
    Also, do you have the Morphs++ pack for V4?
    The normal way to do it, is to select the V4 head in the Scene tab, and then look in the Parameters tab for any sliders to change the appearance.
    It is also a good idea to say what software you are using, since DAZ 3D also produce Carrara, Hexagon and Bryce, as well as selling Poser content. Also the version number of the version you are using.
  • wiibbwiibb Posts: 0
    Hi thanx for the advise about telling what software :)
    It is Daz 4.5 and yes I have the morphs V4 for Daz but just cant seem to get it working
  • JaderailJaderail Posts: 0
    Are the Morphs ++ Injected? Does your V4 Powerloader run and add all the morphs at Load time?
    yes I have ++ Injection morphs
    I have the angry face but can not load it as when I do nothing happens?
    You need to check in the parmeters, and dial in the amount you want with the slider.
    Make sure that you have the Head selected, and then look in the Parameters tab as chohole says.
    Morphs only add to the figures dials, that way you can decide how much or how little to use. Just a Tip.
    I don't get a choice to change it when I insert the angry face morphs?
    809 x 584 - 101K
    Look in Morphs Shapes and Morphforms check all the sections. It should be in there.
    OK thanx will do, it is very much appreciated your help
    :P
  • Richard HaseltineRichard Haseltine Posts: 102,730
    You don't have the head selected there.
    I just checked my V4 in DS4.5Pro. I do not think you injected the morphs. I have a Morphs Expressions in my list after I inject the Morphs ++ package. You need V4 Selected in your Scene Tab when you Double Click the Morph for it to load into V4. Then You should Have a Morphs Expressions when You select the head.
    Your right Richard, you MUST select the HEAD to get to the expressions.
