Saphirewild's Randomness Renders
Saphirewild
Plz be brutally honest with me on this and let me know how I can improve this render cause I know it is not as good as it could be:
Post edited by Saphirewild on
What are you using to render? It is overly pixilated. Looks like the render was stopped mid processing.
I used the IRAY I think it is called? I let it render till it said it was done but I thought it was not done for sure not sure why it stopped like that "Shrugs".
Iray has 3 'stop' conditions...with the time (2 hrs default) being the one that usually stops the render before it's done.
Is there a way I can fix that?
Yes, you can change all three...in the Render settings. Time is probably the one to change.
okies thanks!!! what should I change the time to?
I am excite to share the better render for my "Tip Toe Through The Patio" Scene. I also did a Cartoon one to see how it would turn out.
Plz be brutally honest with me on these pictures as it will help me to grow better in rendering and such.
Any advice will not be taken lightly, I need to improve and grow as an artist.
http://s844.photobucket.com/user/Nancy-Lin_Hovey/media/Tip Toe Through The Patio 3Delight Render2_zps6mjfofqu.png.html
Congrats on the renders, you're off and running and will soon wonder where all the countless hours have gone while doing art.
Okay, one suggestion- where you've cut off the figures in the first scene makes me want the cutoff point to either go up or down. You've got it almost to the feet, but not quite, and you've cut off some of the pumpkin's face but it's right where the mouth/expression is located. My preference would be to either back up the camera so you get that in the image, or zoom in more to the taller characters' faces. It's somewhat in the middle of the two effects. Love the cat's expression and the toon effect. Lighting makes it very easy to see and the shadows add nice emphasis.
Thank you so much for the nice comments and the advice I will remember that for the next time I do the cartoon render.
I also forgot to mention the lighting on the second one lights her backside quite nicely. It also brings out the stone details. I like that the wall behind her is darker, whereas both ends of the scene are lit. That darker area make her stand out.
yes the non cartoon one is much much better than the last one I saw! I agree with Saphirewild on the cut off point. And come over and join us on the newbie contest board for this months contest. Still 10 days left and you will learn a ton! And, its fun lol.
If you haven't already found the answer elsewhere.
I usually just add a zero to the default 7200 seconds (2 hours). If you change it to just a zero I've been told it will go on forever (until it's finished or meet one of the other two stop conditions) but I haven't tried that myself.
The other two stop conditions are "Max Samples" (default 5000) and "Rendering Converged Ratio" (default 95%).
When your render needs lots of time it usually needs lots of iterations too so it's usually best to increase the Max Samples too when increasing Max Time.
And welcome to the wonderful world of Iray! I'm a newbie myself and most useful stuff, like the above, I've learned here on the forum. It's a great place to be.
This IRay is quite confusing for me right now so I think I will stick to 3Delight for now till I get IRay mastered
Thanks Sonja11 I have entered 2 renders in the newbie contest and also added a black render to the Oct Challenge. SO I am well on my way I guess with my art!!!! Still loads to learn though for sure.
Threads merged. Please use one thread for your renders. You can change the title of the thread if you like.
I think this one is better for the cartoon one the mouth is not cut off this time. I do not think I can get this to work anybetter for what I was thinking.
Here is one of me playing around with scaling and with the background!
Here is one I just rendered and played with in PSPX8 wow they have some great tools in this new one!! Even have depth of field in there so played with it a bit on the background.
Cool images - I adore your cartoon characters in wait for the bus - 3 pictures up. I really like the shiny effect.
Thanks I really love the way it shines too PandaB5. I will be posting more as I get them finished as I have about 3 on the go for setting up
Here is one I did last night mostly playing around with the postworks and I know it is a day late ut my way of saying Happy Halloween:
Here is another one I did today I know I know Halloween is over but I could not resist making this cute render.
I was bored so I did one of the lessons in daz tonite......here is the one I did up called: Inside The Asylum!!
Here is my attempt at another cartoon but it didn't turn out quite the way I wanted it to.
Here is one I did today 02/11/2015 I want to see if ev1 gets the story I am telling this time!!??
This one was made for the "Because I said so" challenge I think I did a pretty good render this time! I picked "Don't Ask!" for this render
Here is one I did for the Freebie Contest:
Another Funny Render for another contest:
Beach Beauty Called: Flirting With The Camera
Waiting for the Bus:
