Geoshell for Gen 9, over anatomical elements
It is distressing the way geoshells block out the anatomical elements into white triangles. I just bought the new Gen 9 version of "Vellus Horizon," but cannot use it unless I can figure out how to overcome that problem. For the Gen 8 version, I was able to use the Vellus Horizon the way I wanted to by also utilizing the Visibility product and only turning on what I needed, which did not include Gens. Whether I use the script that came with the Gen 9 product or by creating my own shell, the new Visiblity product for Gen 9 does not work the same way. This HELP section does not seem to have a subject search to look and see if this topic has arisen before, so I must ask for help here. Please.
  • FSMCDesignsFSMCDesigns Posts: 12,776
    Select the geoshell,  then go to surfaces tab, expand the list of surfaces for the geoshell and you should see a listing for the genitals, so select those and turn then opacity down to 0
  • An alternative approach is to use the built in parameter option of a geo shell.
    1. Select the geo shell
    2. Open the Parameters tab
    3. Open the Shell sub group and open Visibility → Surfaces
    4. Switch off the parts you don't want
  • PiquantPiquant Posts: 325
    Thanks to both of you! I appreciate your responses and help. Cheers.
