Issues with DAZ Dog 8
I was working with Brutus the chihuahua, put him in a simple sitting pose, but his lower legs kept changing position. I'd move the whole dog and the and the legs would bend up. I close the file and when I reopen the legs would be bent up again, didn't even have to touch the dog. The only way to fix it was to lock the legs.
I can replicate the problem in an empty scene with just the dog loaded. I'd show screenshots, but of cours the image uploading doesn't work again.
Maybe it's effecting small dogs because I had issues with the French bulldog too.
  • Check, whether you have IK chains in your scene. They usually come with the dog. I tend to delete them. Maybe this helps.
  • barbultbarbult Posts: 24,576
    You can also disable IK (Edit>Figure>Inverse Kinematics). There is a checkbox for Enable IK. Uncheck it. Ctrl+K is the shortcut to toggle that control.
  • frank0314frank0314 Posts: 14,167
    Upload your images to the gallery and don't publish them. You can use the link generated to attach the image to the body of your post.
  • nonesuch00nonesuch00 Posts: 18,230
    You have to deete the IK chains as they auto-adjust positions when in contact with another surface.
  • lou_harperlou_harper Posts: 1,163
    Thanks! I'll give deleting IK a try. I didn't know you could do it from Edit. I've only came across it before when dealing with human figures.
