Looking for poison ring
I am looking for a rigged poison ring that can be opened and closed. Does anyone know where I can find one? Any help is greatly appreciated.
  • nemesis10nemesis10 Posts: 3,477
    There is this though I never have used it in all the time that I have owned it: https://www.daz3d.com/armor-rings I'm not sure if it is rigged but you can see it in the promo picture with the pink guitar on the woman's thumb.
  • felisfelis Posts: 4,561
    A poison ring is a rather specific item, as it shall could be opened, so I would think it will be hard to find.
    If interested, I could probably model a fairly simple ring with that ability.
  • sazzyazzcasazzyazzca Posts: 495
    I have this as well. Sadly, it's a static prop.
    I am not in a hurry, but if you're up to the task, it would certainly be very much appreciated. smiley
  • caravellecaravelle Posts: 2,482
    I have a ring like that, it's hinged, but I can't find it at the moment. It's quite old, but I'm sure that's not a problem. I think it was a freebie from shareCG, but I can't remember who made it either... Sorry! As soon as I find it, I'll let you know.
    Maybe caravelle can find where such a ring can be found.
    Anyway, here is a fairly simple rigged ring.
    It is saved as a prop (not a smart prop), so it will load in world center and you must move it to the intended finger and parent it. For moving an object I recommend to use 'object coordinates' (setting in Tool Setting) as that will make it much easier to place. It might also be scaled. I made the inner diameter 16 mm, and for the attached G8F I scaled it to 110%.
    There are no textures (it is UV unwrapped) , only surface settings, currently silver for the ring and some gem-like for the gem, but you can change them to your liking.
    1200 x 1200 - 2M
    1200 x 1200 - 2M
    1200 x 1200 - 2M
    zip
    zip
    PoisonRing.zip
    74K
    Wow, felis, this one looks much better than the one I own! I just dl it; thank you very much for sharing it!
    I'm in the same boat lol. I'm certain I had either bought or downloaded one many years ago, but can't find it.
    Thank you so very much!!!
