Light Panel Obj
Catherine3678ab
Basically, just the .obj to use as a light panel in D/S or any other program you want. No textures or other scene stuff included.
In D/S, import using Daz measurements, resize and position to where you want it ... hiding or removing all else from the scene, export out the .obj. Then remove that from the scene. Import back in your new .obj file; apply desired shader presets etc. and save as a Figure/Prop to a sensible location.
UVMapped so one can use texture images.
At Renderosity.
857 x 1000 - 457K
Thank you, Catherine! Just what I needed, right when I needed it! :D
The camera position forced me to put a ceiling up there that blocked out the outside lighting environment and my earlier render of this scene was way too dark!
Glad to see it found a good home :-)
Working on some more light panels, round etc.
Here's one teaser:
https://www.deviantart.com/catherine3678ab/art/More-Light-Panels-978856774
Looking forward to that one!
It's uploaded to Renderosity, 2 Round Discs.
Package includes 2 round discs. Each with their own Shading Domains.
One loads on the floor [spinner] and the other one a little higher. Can make light panels, spinning boards, whatever, have fun :-)
Thank you!
You're quite welcome, enjoy :-)
