What is the purpose of 'Perspective view' always returning to 0,0,0 after the program is closed?
So far I can't see something useful from this "feature". Is someone needs a quick return to the Zero point of the perspective view, a simple RMB click or something like this on an approriate spot will be more than enough.
If there is something useful from this "feature", please tell me. Because I found only annoying problems from it.
  • WendyLuvsCatzWendyLuvsCatz Posts: 38,563
    the only reason you have this issue is DAZ Studio unlike many other programs doesn't load with a default camera
    I have the opposite issue in ones that do
    that said I never understand why in all my programs the cameras always load in unusefull default positions unless set in options
    you can set it to load a saved scene though with a camera, environment, tone, lights etc but then you need to remember to not save over it
  • The whole point of perspective View is that it is not tracked, saved, or added to the undo stack - it's a working camera that you can use without interfering with other actions. If you need to keep a view, create a new camera and use the option to copy the active view (which would be perspective at that point).
    And there is an option in Edit>Preferences (Daz Studio>Preferences for Mac) in the Scene tab to have DS create a Default Camera, if you want.
