How can I rotate a object in 360º like a ventilator (clockwise and counterclockwise)
I'd like to use a primitive cone-shaped figure and put it to spin like clockwork. I need to learn how to do this clockwise and counterclockwise.
Post edited by gabriellesmoura2021 on
Let's keep it simple. If this is for an animation which it sounds like it is, then once you have your object in the scene where you want it to be, select the part you want to spin, go to the rotations under the Parameters tab, and use the Y Rotate slider to advance it in the direction you want, and correlate that with the timeline in your animation. You can also use the Universal Tool to accomplish translations and rotations. Start there and work through it. I have no idea how complex or simple your idea is so ...
Causam3d.com: Easy to use, sophisticated assets for Daz Studio.
