Morph Loader Doesn't Appear in Parameters Tab
Hi!
I have been following the Petunia Petals process to convert G9 Clothing and hair to G8.
The process works up until the step I need to use the Morph Loader menu in the parameters tab.
I have successfuly saved the morph in the DAZ Library but Morph Loader is not an option.
Is this a context specific menu item that is only available if everything and saved and filed correctly, or should it always appear?
I have been using DAZ for a while but without user documentation it's hard work to figure out the internal logic.
>>>https://www.renderosity.com/freestuff/items/93282/making-genesis-9-auto-fit-clones-for-g8-tutorial<<<;
  • lilweeplilweep Posts: 2,489
    edited August 2023
    i didnt read the tutorial or anything (as soon as i saw emojis in the text description i bailed), but Morph loader pro can be accessed from Edit>Object>Morph Loader Pro
    By the way, if you are using one of the default workspaces (Window>Workspace>Select Layout) such as the City Limits one, i think you will have morph loader pro as a toolbar action too.
    EDIT: Oh, you mean after loading the morph via morph loader pro, you cant find your morph in parameters pane? The morph will be in whatever path you put it in when you used morph loader pro.  In Morph Loader Pro, the default 'property group' is /morphs/morph loader.
    But if you loaded it with a different path, you can just search for the morph in the parameters pane by typing the morph name.  Presumably you know what you called it.
    Post edited by lilweep on
  • Open the morph you saved with a text editor. Search for 'group' ... that will be where it was saved to on the Parameters Tab.
