Bringing order to the viewport
in New Users
HI
I can manage to drag a panel out of the side space where its docked, but for the life of me i dont seem to be able to move panels into an order that I like them to be in. For example in the attached screen shot I would like Render setting to be below surface but try as might, I cant make that happen. Any ideas please...
You can do this but instead of dragging the tabs to the empty space between other tabs or at the end where you want them to go you have to drop them over the top of existing tabs instead. A little counter-intuitive but it does work.
Although I did have an issue the other day where the order of all my tabs except the first one in each area of the screen reversed there order somehow.
I'm sure Sofa also knows this, but make sure you save your screen layout when you make these changes.
So simple if less that obvious, and it works and I saved the layout, thank you so much
