Where do I find Filament?
in The Commons
Hi all, I just discovered there is another render engine called Filament, but I can't find where it is or how to use it, and the link to the tutorial doesn't work. Can someone point me in the right direction, please? Thanks!
In your viewport, upper right corner, you have a menu. Left of that a square button where you can select 'perspective view', 'cammera' etc, and left of that a small icon called drawstyle. There you can select Filament.
I would suggest to also Create > New Filament Draw Options Node, so you can adjust some settings.
Awesome! Thanks so much! :)
That’s assuming you're using Windows, as Filament is not yet available in the Mac version (the Qt framework upgrade which will be included in DS5 is required for Filament to work on a Mac)
