Chocos the Monkey (G9) throwing warnings during G9 Dev Load
Chocos the Monkey (G9) throwing warnings during G9 Dev Load (posting for dev FYI)
https://www.daz3d.com/chocos-the-monkey-for-genesis-9
https://www.daz3d.com/hypertaf
While loading a G9 Dev Load Character, I'm recieving the following truncated list of errors pointing to Chocos the Monkey for Genesis 9. This is currently the only product in my library showing errors/warnings.
BEGIN:
2023-09-02 16:57:07.231 [INFO] :: Creating property aliases...
2023-09-02 16:57:07.245 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(9331): Alias node reference not found: CTM%20Tail:/data/Hypertaf/Chocos%20the%20Monkey/CTM%20Tail/Morphs/Hypertaf/Base/Tail%20Roll%20R.dsf#Tail%20Roll%20R-0xa093bdb?value
2023-09-02 16:57:07.245 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(1744): Property alias not created!
2023-09-02 16:57:07.245 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(9331): Alias node reference not found: CTM%20Tail:/data/Hypertaf/Chocos%20the%20Monkey/CTM%20Tail/Morphs/Hypertaf/Base/Tail%20Roll%20Left.dsf#Tail%20Roll%20Left-0xa093bdb?value
2023-09-02 16:57:07.252 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(1744): Property alias not created!
2023-09-02 16:57:07.252 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(9331): Alias node reference not found: CTM%20Tail:/data/Hypertaf/Chocos%20the%20Monkey/CTM%20Tail/Morphs/Hypertaf/Base/CTRLTailRollUp.dsf#CTRLTailRollUp-0xa0927e4?value
2023-09-02 16:57:07.252 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(9331): Alias node reference not found: CTM%20Tail:/data/Hypertaf/Chocos%20the%20Monkey/CTM%20Tail/Morphs/Hypertaf/Base/CTRLTailRollSides.dsf#CTRLTailRollSides-0xa093bdb?value
..... Truncated END
  • Posting this here will never get dev attention. The forums are peer to peer. The only way to contact the "powers that be" is to file a ticket.
  • crosswindcrosswind Posts: 7,960
    Because there're a couple of wrongly-set alias on G9 from this monkey... even if you directly loaded the monkey itself, you would get these warnings as well. There's no impact on anything 'cause these alias will be totally useless on G9, with the wrong settings... If you don't like these warnings -:
    go to the folder - : 'your Daz Library'\data\DAZ 3D\Genesis 9\Base\Morphs\Hypertaf\Chocos the Monkey, there're 12 files initiated with 'alias_', delete them all and reload you Dev.
    Then send a support ticket as you wish...
  • Thank you.
