[Released] Amorphozoa
![Oso3D](https://delorean.daz3d.com/forums/uploads/userpics/964/nKUSSXH2JM34Y.jpg)
I shall name him squishy!
This subterranean shapeshifting creature has a number of uses in fantasy and science fiction renders. Without the odd shapes, it serves as a flexible and creepy vaguely starfish-like creature. With the ability to take on various guises, it adds an element of surprise and dismay.
And for even more weird shapes and textures:
The creature is designed with a geoshell that can take various disguise textures. Disguises have several stages of masking, to shift from full disguise to stages of less coverage.
The disguise can also take any texture, such as environment elements from a scene, with a special shader that allows you to tile the texture as needed without changing the mask that blends it into the creature.
Interesting. Just could not resist.
Bought this and the extension. Problem is, I don't see the extension stuff anywhere included with the figure. Is it hidden away somewhere else? Installed with DIM.
The extra shapes should be on the figure when you load it.
If you use smart content, clicking on Materials or Poses or whatnot should show you the appropriate extra stuff.
In the Content Library, there should be Animals/Oso3D/Amorphozoa and Animals/Oso3D/Amorphozoa Extended
Not showing up in Smart Content, but certainly is showing up in Content Library. Will use that then, thanks. You thinking about doing a slime material for this too? Would love to see that!
