Minor issue with Ye Old Library
I'm having a minor but odd little problem with Predatron's Ye Old Library sets - it seems none of their content can be added to the Categories section in the Content panel.  I've been adding a lot of folders from various products to gather all my fantasy props into a single category, but every time I try to add anything from Ye Old Library, it just adds an empty folder. I've tried logging in through Studio to update the metadata, etc, but it only appears to be that product. Does anyone know why this might be happening? Nothing else wrong with the product, it's just weird. Thanks in advance.
  • I was, in the Product in Smart Content since that was what I had open and to hand, able to right-click>Categroise and then select Props>Tools for the YOL Candle Lighter. Can you do that, or is that failing?
  • SnowSultanSnowSultan Posts: 3,620
    edited September 2023
    No, I tried it with the same item and the directory that it creates and goes into is blank. This is the only product I've had this issue with out of about 30 though. I will try reinstalling it, but otherwise I'm not sure what could be wrong.
    (edit: forgot to mention, I tried putting it into the Props>Tools folder like you said and my own custom Category. It does not appear in either).
    Post edited by SnowSultan on
  • I installed through DS, so never had DIM metadata. I can't see anything else that might account for the difference.
    I'm pretty sure something is wrong when installing through DIM then because I reinstalled it and when I was logged in with DAZ Studio to update the metadata, a warning briefly appeared that said "two products failed". It's also the only product I've noticed in DIM that does not show a tiny thumbnail when installed.
