GENESIS 9 - MORPH LOADER PRO [PROBLEM MORPHS]
Can anyone tell me why a morph created with blender sculptiong also changes my character scale when I load it with morph loader pro? I did not use genesis 9 base avatar
  • Almost certainly you used a different preset on the OBJ export and the Morph Loader Pro import - OBJ has no inherent sale, or orientation, so the presets tell Daz how the values should convert for the OBJ. Using the same preset ensures that the process is properly reversed. Try an OBJ export (of anything) and note which preset is used, then cancel and redo your morph import setting the same preset.
  • crosswindcrosswind Posts: 6,990
    Blender's default Unit is meter while DS is centimeter, pls first ensure that you export from DS with 100%, import and export from Blender with 1%. If the issue still sustains, better post a screenshot.
    461 x 548 - 49K
    953 x 744 - 108K
    952 x 744 - 131K
