How to a export prop edited in geometry.
How can I save and export a prop I edited in the geometry editor? By that, I mean to also import that same prop with shader parts and all.
  • eshaesha Posts: 3,254
    If you mean to use it in other software, go to File > Export > set OBJ file format.
    However, that does not export all the shader settings. Only in Daz Studio you can get all the particolars of a Daz Studio shader.
    If you want to save your prop so you can use it in other Daz Studio scenes, best thing is to save it to the library:
    File > Save As > Support Asset > Figure/Prop Asset
    Then fill in the dialogue.
  • If you're talking about saving the edited version as something you can reuse in Daz you can do one of two things:
    1. Save the prop as a "Scene Subset" and then it will just load the prop and other objects as you saved it
    2. Save it out as a new prop asset.
