Blender file in Daz Studio…
Hi all !
I'm asking me if it was possible to import 3dsmax file (environnement) in Daz Studio ?
I've found the free plugin to export to 3dsmax but not the opposite...
  • No, there is no built-in importer for .3ds and I am not aware of any add-on for the format.
  • OK so if i want to use my 3dsmax file (it's an environnement) i have to make my scene in Daz Studio and export it with a bridge to Blender, is it right ?
    Thanks a lot
  • You could always export it from 3DS as an OBJ file into Daz if that's possible. And then yeah, use the diffeo plug-in to bring it from Daz to Blender, unless you just import the OBJ into Blender too. I don't know your whole situation, so you might need to go into Daz first. Good luck!
  • lilweeplilweep Posts: 2,557
    edited September 2023
    Thanks a lot
    explain the logic of bringing something to Blender when you want it in Daz Studio?
    There is no importer/bridge of Blender nor 3dsmax scenes to Daz Studio.
    If you have downloaded an environment like an Evermotion 3dsmax environment, as an example, then it will be a painful process of manually importing to Daz Studio using obj, and manually setting up/correcting materials/textures.
    Post edited by lilweep on
