Genesis 8 to 9 animation converting
Hi,
I have a lot of animations (not only poses) made for genesis 8 and want to use for genesis 9.
There are plugin.script for poses but not found any doing animation convertion.
Is there a solution to convert the animations, aniblocks or even ;bhv via another product ?
thank you
Olivier
  • Bone minion from river soft will transfer the animated key frames from 8 to 9. I've used it and it works just fine.
    edited September 2023
    Yes! Bone Minion!!!
    I have some tips for you:
    When we apply a Bone Minion, by default it reads everything we do to it to the figure it's attached to, which will record the animation to the timeline, whether it's an aniBlock or whatever.
    So set the timeline (using the timeline hamburger menu on the right side) to "Play All Frames" so it doesn't skip over any.
    Also, if you want to work a bit before converting, select the Bone Minion and, in the Properties plane, uncheck Auto so that it's not constantly writing keyframes/poses. Then simply turn it back on and hit play when you're ready to do the conversion.
    In my experience, Bone Minion does a Wonderful job! Of course, no joint pose conversion can be absolute correct as the rigs are set to mesh somewhat differently, but Bone Minion has given excellent results for me time and time again! Big Fan!
    I'm in the same situation, but mine are all for Genesis 3. So after trying the Genesis 3 Pose to Genesis 9 Bone Minion, I went back and bought the whole Genesis 3 Pose Bone Minion Bundle, so that I have a Bone Minion for Genesis 3 poses for Genesis 1, 2, 8 and 8.1 as well. Love it! There's a bundle like that for Genesis 8 poses too, if you're interested.
    Post edited by Dartanbeck on
  • olemolem Posts: 5
    thank you for your advices
    To convert Genesis 8 poses to make genesis 9 animations, what Bone minion version it is ?
    This One transfers Genesis 8/8.1 poses and animations to Genesis 9
