Having trouble setting keys for animation
billh4321
What I'm trying to do is create an animation where each pose control for example with Genesis is keyed at each frame. Then I'll export to say Blender and I'll be able to save each frame as a pose.
So: at Frame 1, Arms Up-Down = 0, at Frame 2 = 1, at Frame 3 back to 0 Using either Linear or Constant Interpolation. Is there any informaiont for either script or plugin that demo's setting keys?
Things I've tried allow me to set keys however, the joints seem to float around.
Thanks
I would checkout @mCasual's excellent resource of scripts. In particular: https://sites.google.com/site/mcasualsdazscripts/setinterpolation-for-ds2-3 may clue you in to what you're after.
Yes, that's usually where I end up. Turns out that I was setting keys on hidden properties which was causing my problem.
Thanks for the response.
