Light abs
The existing ab morphs that I've used so far push the rectus abs out and create some outer detail seperating them from the obliques. I'm looking for the kind of light abs that can sometimes peek through when a person who normally has a flat abdomen laughs or shouts. Those abs are usually just in the center and laughing doesn't reveal the obliques. It seems like this effect could be achieved if there was a morph for the rectus abs that indents the abdomen rather than pushes the abs out. Does such a product exist?
I don't know if there is one for the current generations of genesis figures, but there is this belly pack for older figures. Maybe using the search terms, belly or stomach, might help you find other options.
Belly Control Bundle | Daz 3D
Search Shape Shift, from Zev 0 as well. https://www.daz3d.com/shape-shift-for-genesis-8-female-s
TY, that sort of worked. There's a "belly shape define" slider in that pack that indents the linea semilunar. I set it to negative numbers and it smoothes out the area between the rectus abdominus and the obliques.
