Can I make manifest file?
![LambdaX](https://secure.gravatar.com/avatar/3a9075979d62f4ab39c5be41407e66a9?&r=pg&s=100&d=https%3A%2F%2Fvanillicon.com%2F3a9075979d62f4ab39c5be41407e66a9_100.png)
I wonder if I could make manifest file to install contents by DIM.
I want to add the file to my free products so users can install them easily.
I know how to use it to install contents but don't know how to make the file.
I wish I could.
Yes you can, with this product - https://www.daz3d.com/content-package-assist
Thank you. It will help me.
Moved to Technical Help as it is an Install Manager question, not a Daz Studio question.
As mentioned above you can easily do this, and better yet: you don't even need to purchase anything either because it's fully supported by Daz Studio itself. The keyword is: Content Library pane. It's actually quite easy:
Make sure that your 'assets' are fully set up as well (see "Assets" tab) and for best results it's obviously a good idea if you add your assets to the smart contents pane prior to creating the product, though this isn't mandatory.
After you have everything set up your can click "export" and that should do the trick. The support file ("dsx") will also be mentioned in this product screen as well.
Well, that's roughly it. Really no need to spend money over this.
Nah... actually OP needed IM package with Manifest.dsx to install a product rather than a product metadata file.... They're totally different...
I beg to differ. Maybe this is also a good read:
https://www.daz3d.com/forums/discussion/23697/creating-your-own-dim-install-package
Bottom line: you don't need to purchase anything, Daz Studio is perfectly capable of handling everything on its own.
I don't need to... but probably OP does. I've been playing DS for 6 years.. I can write a script to generate shared XML(s). I just recommended a product when it was just $5.5. That was up to OP to check and decide. Anything wrong ?
You don't have to impose your opinion, just giving a proper advice will be fine. Before that, better really understand what OP needed. Sorry, I certainly know what DS is capable of, but eventually who can get the job done is the one who uses DS...
