problem with using strand based hair,bug?
when i do big change in strand based hair,in style function.i use curl curve panel and surface attact curves to style the hair.but after that ,clumping and scraggle function wont work.even after restart daz,after reset curves in style panel.what happend?
  • this is the problem file
    duf
    duf
    style2.duf
    20K
  • lilweeplilweep Posts: 2,553
    that file doesnt work.
    Never had that issue.
  • Are you sure it is Curl and Surface Attract causing the issue? Are you able to reproduce the bug by doing it on new hairstyle?
    Scraggle requires low Interpolation Segment Length.
    Clumping can be impacted by Single Guide, Autoparting, and Random Root Angle
