Genesis 9 Character Help!
![donna.sally4](https://secure.gravatar.com/avatar/ca7cbd48a7f144b369b789e722018522?&r=pg&s=100&d=https%3A%2F%2Fvanillicon.com%2Fca7cbd48a7f144b369b789e722018522_100.png)
in New Users
Hi, my name is Dana. I'm new to Daz. I'm hoping I can get a little help. I can't seem to get my Genesis 9 character's limbs to move. The whole body moves in one motion. The pre sets work well with 8 but 9 is a headache. Any tips?
Thanks in Advance!
Not sure of what you mean, you mean you manually move the limbs by sliding XYZ Translation / Rotate, or using gizmo or applying Pose Presets?
Is it a selection problem, you can't select limbs by clicking on them? That may be down to the tool that is active (look to see which has a check in the Tools menu - for posing you usually want the Universal tool) or selection mode if the right tool is active (in the Tool Settings pane make sure that Node Selection Mode isn't Root Node Only - though you can use the Scene pane for seelction too, if you click the triangles to expand the hierarchy).
