Need help for hair : ColorWerks 3 and scalp problems
Hello, I don't remember having this problem before, but when I use ColorWerks 3: Dye Another Day Iray Hair Shaders on my current work, I apply an hair shader and use the script for the scalp as told in the product, but I get a very bright scalp that looks kinda weird. The  red shader on scalp and hair is the same (ruby). What could be going wrong and what could I do to fix it ?
1920 x 1080 - 2M
  • butterflyfishbutterflyfish Posts: 1,258
    edited October 2023
    Is it possible the hair just isn't fitting correctly? I'm not seeing that in preview or iray when I use that hair.
    1427 x 816 - 2M
    Post edited by butterflyfish on
  • I dont know, it's true that this hair and this head morph aren't the best friends ever, but when trying other hair shaders like OOT, the weird color tbug doesn't appear :/
    Also removing the smoothing modifier will not resolve the glitch...
  • DaventakiDaventaki Posts: 1,624
    Well from my testing with the same hair and color it is fine even with bright lights but as soon as a smoothing modifier is added it messes up even if I turn it off.  Have you tried deleting the hair and adding the color before you do the smoothing modifier?
  • Thanks Daventaki, you're right that it is the smooth modifier that ruins the shader on the cap :( That's super annoying because I really want to use this hair for this character (they're the most accurate, this character was created out of DAZ and this is her 3D rendition). I then need to find how to make those hair fit this head without problem - and seemingly without smooth modifier :/
